If you download the simple model data.mdl, cllck on the eqation editor, click on level, click on eqation 2 and click back on eqation 1, the type of the eqation becomes data, and the equation disappears and if you click to equation 2, equation 2 becomes data too and disappears. To revert to the original equation you have to quit the editor and use the editor again, where the original eqation is left unchanged.
possible slight problem
- data.mdl
- (1.55 KiB) Downloaded 169 times
Re: possible slight problem
There is a version 6.0A-1 on the Vensim website, this is there to fix this problem.
Can you try it?
Can you try it?
It works fine with the new version.
