Hi!
I've a slide with textmenus. I shift to another slide selected trhough a textmenu. When I go back to the first slide, it is blocked, I can't press any Textmenu.
I tried with the command "SPECIAL>REFRESH" with no success.
The first textmenu I pressed keep highlighted in the second visit of te slide.
How can I "reset" the choice and have a working slide again?
Thank you very much.
[Venapp] TEXTMENU working just once
Re: [Venapp] TEXTMENU working just once
Can you post the venapp you are using? It's impossible to really advise you unless we can see what commands are being executed.
I got it!
I used TEXTMENU with no text ( ) to have empty region as link.
When I returned on the slide where there is the starting TEXTMENU, it was blocked, the entire slide was blocked.
I replaced TEXTMENU,"" with (introducing a space as text) and the all worked well.
TEXTMENU,""
TEXTMENU," "
