Fish Stocking Model
VTHokie
Vensim version: PLE+
Fish Stocking Model
Post by VTHokie »
Hello All,
I am working on a grass carp stocking model which simulates grass carp herbivory on aquatic plants over the long term (20 years). My question is: Is there a function in vensim PLE+ that I can use to alternate the number of fish stocked annually (inputs into the model)? For example, I need to program 6000 fish stocked in year 1, 3000 in year 2, and 1500 in year 3, with each stocking occurring in April. The modulo function works for a constant stocking rate, however I was hoping someone may provide insight into handling different levels of stocking.
Re: Fish Stocking Model
You could use a lookup table combined with modulo.
fish restock F ((1,6000),(2,3000),(3,1500))
fish restock = fish restock F (time)
VTHokie
Post by VTHokie »
Oh yes, of course. Thank you!
Another option would be lookup + PULSE TRAIN as the trigger. PULSE TRAIN may be a little simpler to use than IF THEN ELSE( MODULO(Time, ... )), as you don't have to worry about roundoff and time step boundaries.
An example ...
fish stocking.mdl
(3.84 KiB) Downloaded 243 times
VTHokie
Post by VTHokie »
Great, that will work perfect for inputting the grass carp stocking regime into my model. As a newbie to Vensim and systems modeling, I really appreciate your suggestions.
VTHokie
Post by VTHokie »
Hello Everyone,
I have another vensim programming question. Is there a way to program a lookup to repeat at the same time-steps annually? I plan to model grass carp increases in weight over the growing season to accurately portray aquatic plant consumption (which is a function of grass carp body weight). I have calculated weight at each interval over the growing season for all age classes in my model (1-16). My model runs on a montly time step where grass carp advance to the next age group after 12 months. I planned to use a lookup to model increases in weight, for example at age-1 monthly weights (kg) for grass carp are ((5,.25),(6,.5),(7,1),(8,1.6),(9,2.2),(10,3),(11,0)) where growth only occurs between May and October when plants are present, and the 0 in November resets it for the next stocking to come in. While this works for one year, I plant to simulate 20 years of stocking, and repeating this lookup 20 times doesn't appear feasible. I'm guessing there's a much easier way to do this, but I haven't been able to find it in the vensim documentation. I appreciate any insight you can provide.
Right - rather than using
carp growth lookup(time)
just use
carp growth lookup( MODULO( time, months per year ) )
with months per year = 12.
