demand and supply at price
kong17
Re: demand and supply at price
Post by kong17 »
I have solved the question that I asked above and there is only one demander.
but when I discretize the demand into multiple segments to represent different needs at different times of every year, and each segment should be equalibrium.
the model reports an error, but I don't know how to solve it.
I uploadded a simple example, I was wodering what's wrong with it?
Thank you very mcuh!
Best wishes
EXAMPLE.mdl
(4.87 KiB) Downloaded 155 times
If you step through the elements of "priority vector" you will find that the first element has [duration,supplier,ptype] and the next has [duration,supplier,pprofile]. That doesn't work because pprofile is the range. If you replace it with the element ppriority it should work.
kong17
Post by kong17 »
tomfid wrote: Tue Jan 21, 2020 5:41 am If you step through the elements of "priority vector" you will find that the first element has [duration,supplier,ptype] and the next has [duration,supplier,pprofile]. That doesn't work because pprofile is the range. If you replace it with the element ppriority it should work.
Hi, thanks.
that is my mistake.
Now the model can running, but it did not achieve the results I thought, the each segment can reach the supply-demand equlibrium at a certain market price. Is there a problem with my subscript usage or a problem with subscript setting? So, I have so many questions.
EXAMPLE.mdl
(4.94 KiB) Downloaded 159 times
You've mixed up the subscripting by deleting the "demander" dimension. Therefore FIND MARKET PRICE is iterating over suppliers on one side of the market, and durations on the other side.
The solution is to preserve the demander range, with length 1:
demander : total
Then use that in the demand variables:
FIND MARKET PRICE(demand[duration,total], demand priority vector[duration,total,ptype]
,supply capacity[Coal], priority vector[duration,Coal,ptype])
DEMAND AT PRICE( demand[duration,demander], demand priority vector[duration,demander,ptype] ,market price[duration])
demand priority vector[duration,demander,ptype]=
	demand priority type ~~|
demand priority vector[duration,demander,ppriority]=
	demand priority[duration] ~~|
demand priority vector[duration,demander,pwidth]=
	demand priority width ~~|
demand priority vector[duration,demander,pextra]=
	extra
You can compute the net demand-supply as a check (should be 0 for each duration):
SUM(amount demanded[duration,demander!])-SUM(amount supplied[duration,supplier!])
kong17
Post by kong17 »
tomfid wrote: Tue Jan 21, 2020 3:52 pm You've mixed up the subscripting by deleting the "demander" dimension. Therefore FIND MARKET PRICE is iterating over suppliers on one side of the market, and durations on the other side.
demander : total
	extra
Yes, it is solved. Thank you very much.
