How can I use a model with database operations in java ?
hi.
I can run java example comes ; java example of the model will address modification model for database operations can not run my establishment .
But vensim mine is running .
Can anyone tell me how to do ?
Re: How can I use a model with database operations in java ?
I do not understand your question.
Can you explain again? Can you upload your model?
Administrator wrote:I do not understand your question.
oh,sorry.
My English is poor.
java
result = vensim.command( "SPECIAL>LOADMODEL|C:\\Documents and Settings\\All Users\\Vensim\\odbc2\\odbctest.vpm" );
result = vensim.command( "SIMULATE>RUNNAME|1" );
result = vensim.command( "MENU>RUN|O" );
when it runs,some error like that
Stop from Vensim
Problems encountered in the simulation.
enter
the model can run in vensim dss.
- odbc2.zip
- (1.44 MiB) Downloaded 165 times
What values are you getting for "result"? It should be =1 if the command has executed properly.
result = vensim.command( "MENU>RUN|O" );Administrator wrote:What values are you getting for "result"? It should be =1 if the command has executed properly.
After executing the above code
result = 0
before result value is 0 ,there has two dialog ("确定" it means ok or enter): when i click "确定" button,it will pop the other dialog: My java code logic is right?
Is there any conditions need to be set in advance ?
this is the publish .vpm file dialog.
Are you using a recent version? There were some problems in the ODBC example prior to 6.2 or 6.3, as I recall.
tomfid wrote:Are you using a recent version? There were some problems in the ODBC example prior to 6.2 or 6.3, as I recall.
oh,the version is 6.1c .
I will try the recent version.
thank you
I using the recent version,the result is 0 too.
Whether that version the .vpm file run in java alway show me the .vdf file is protected,when I choose another one,it can run and delete .vdf file what I choose.
Is it a bug?
or
I operate it in the wrong way.
help!!!
Is it a bug?
or
help!!!
When you publish, do not include any files and untick the "Settings" box.
What value to you get for "result" when you open the model?
Also, using "1" for the runname is theoretically OK, but potentially troublesome, because that means your vdf will be named 1.vdf, which might have side effects. Can't say as I don't do it.
