summing over subscript ranges
Summing over the entire subscript range is easy using sum(!). My question is: Is there a way to sum over the first (or last) n elements in an m element range (m>n)?:(
Re: summing over subscript ranges
If the number of elements you want to sum is fixed, it's more efficient to use a subrange, e.g.
sub : (s1-s10)
subr : (s1-s6)
myvar = SUM( myothervar[subr!] )
sums over the first 6 elements of the 10-element range, without having to iterate over the elements s7-s10 that aren't needed.
The VECTOR SELECT function is also often useful when you want to sum over sparse subsets of a range.
sub : (s1-s10)
subr : (s1-s6)
