Hi again,
I am using a set of annual data in order to drive a model. I am using a time step equal to 0.0625 so that the model calculates 16 values per year/variable.
The point is that when I use the GET XLS DATA function with a set of data such as the one below:
Year Value
2000 5
2001 6
2002 7
Vensim does not hold the value of the variable constant along each year. For example in year 2000 the value increases in each time step from 5 until it reaches 6 in year 2001.
My question is: Is there any way to tell Vensim to keep the values constant until it gets a new value from GET XLS DATA? Otherwise it seems I'll have to build an Excel with 16 constant values per year in order to run the simulation
Thanks again,
Santiago
Question on GET XLS DATA
Re: Question on GET XLS DATA
Can you please have a look at the model and Excel attached? I don't know what I'm doing wrong but if I table the 'Read data' variable I can only get the data at the specific years (2000. 2001. 2002. etc.)
There is no data at the intermediate values (2000.25, 2000,50, 2000.75, etc.) in case I use any of the options (Interpolate, hold backward, etc.)
Santiago
Santiago
- Test HOLD.mdl
- (1.05 KiB) Downloaded 184 times
- Data.xlsx
- (8.73 KiB) Downloaded 194 times
The data variable won't contain any interpolated or held points, but when it's used, you'll see them downstream.
For example, try:
myData := GET XLS DATA( ... )
myAux = myData
Then play around with the interpolation pattern and take a look at myAux.
For example, try:
myAux = myData
Ok. Got it now.
Thank you very much again!
