I cannot open the model that I am working on, but I have no problem opening other models. I updateed my Vensim and still cannot open this model. I attached the model. Thanks for your help!
Best,
Kai
Cannot open the model
- ALI Municipal V1.mdl
- (41.75 KiB) Downloaded 212 times
Re: Cannot open the model
That's an empty file.
Where did you get it from?
That is my model which I have worked on several weeks. I do not know why I open it and see nothing there after restarting my computer. Can it be recovered?
Best,
Kai
Best,
Kai
It's a blank file, there is nothing there to recover.
Do you have any other files in the same folder? One of those might have something that can be recovered. Or did you have the backup path set up in Vensim?
I don't think I set the backup path in Vensim. But I do have a file in the same folder. The original file is not allowed to attahced (don't know why), so I zip it and attached.
- ALI Municipal V1.zip
- (7.41 KiB) Downloaded 203 times
That file does have some model equations and views.
- (41.72 KiB) Downloaded 203 times
I just changed the ".2mdl" to ".mdl" and recovered my model. Thanks for your help!
Best,
Kai
Best,
Kai
