Mortality rates in a cohort model depending on creation time of the cohort
moudi
Re: Mortality rates in a cohort model depending on creation time of the cohort
Post by moudi » Wed Mar 15, 2017 10:25 am
I implemented a most basic structure including incidence of coronary heart disease and incidence of high blood pressure (no real figures, only piping and plumbing). This model would work. However, the question is if from a programming point of view there is a serious concern against this solution?
Best regards
CohortPopGroups3 fixup mortality group basic.zip
(27.33 KiB) Downloaded 72 times
venacar
Newbie
Post by venacar » Wed Jun 14, 2017 8:11 pm
moundi, thank you for your model. It is very useful and it helped me a lot. You should have a lot of knowledges to use all codes just like playing an easy game
moudi
Post by moudi » Thu Jun 22, 2017 9:14 am
A model has been created where as suggested above the mortality rates of each cohort with CHD depend a) on the age of the cohort and b) on the time since the event. Two models are uploaded here. In the second model (Test Group Cohort1r) the cohorts are deleted if population falls below a minimum value, in the first model (Test Group Cohort1q), this element has not been included. The first model (1q) behaves smoothly towards the end of the simulation period, whereas the second one (1r) shows irregularities and even wrong behavior.
I would be very happy to receive a hint, what the problem could be with the second model.
Best regards
Test Group Cohort1q.zip
(23.98 KiB) Downloaded 53 times
Test Group Cohort1r.zip
(25.41 KiB) Downloaded 61 times
moudi
Post by moudi » Sat Jul 08, 2017 7:50 pm
I realized only recently that in the models presented above, there was an error. I post two models here (Test Group Cohort 1m; Test Group Cohort 1n), where the second builds on the first. In the second model "Incidence Rate CHD" is the inflow to "Head Cohort with CHD
Population with CHD". The first model seems to be OK, while the second model shows a number of warnings. It happens that "Head Cohort with CHD" can be empty, and therefore a problem with a reference arises.
Two questions: a) is the problem present already in the first model, but did not play a role? a) How to address the problem?
Best regards and thanks
Test Group Cohort1m.zip
(19.28 KiB) Downloaded 54 times
Test Group Cohort1n.zip
(21.23 KiB) Downloaded 57 times
