Graph
leon
Graph
Post by leon »
How can I display several behaviors on the same graph from my model? For example, I have a variable "initial rate", then I want to see all the behaviors of my outcome variable displayed together for 5 different inputs for initial rate.
Re: Graph
Just give your runs 5 different names and be sure that all 5 datasets are loaded.
If you're using a custom graph, you can use *1, *2 ...*N as a wildcard to fill in the Nth loaded dataset.
