Hypergeometric function
- Vensim version: PLE
is there any way of implementing an hypergeometric function 1F1 with 3 parameters a, b and c in Vensim PLE Plus obviously through some other functions?
Al the best and many thanks for any suggestion.
Lorenzo
Lorenzo
Re: Hypergeometric function
Can you give an example of what you want to implement?
And if you upload what you've tried, that would help as well.
HiAdministrator wrote:Can you give an example of what you want to implement?
thank you a lot. I'm trying to use Vensim to model a probability of infection with a relation I found in Teunis et alii 2016 "A generalized dose-response relationship for adenovirus infection and illness by exposuere pathway" where you can read that (relation (2))
Pinf(dose|a,b)=1-1F1(a,a+b, -dose)
At the present I've no model to upload, sorry.
All the best.
Lorenzo
Have you tried to replicate the 1F1 function in Vensim? The source code (in C (GNU Scientific Library)) is available on the internet.
HiAdministrator wrote:Have you tried to replicate the 1F1 function in Vensim? The source code (in C (GNU Scientific Library)) is available on the internet.
I just looked for some definitions and I found out some here
http://functions.wolfram.com/Hypergeome ... ric1F1/02/
but none, imho, directly replicable in Vensim.... any suggestion? I'm using Vensim PLE.
Lorenzo
I found this site
http://keisan.casio.com/exec/system/1349143651
that looks nice. Unfortunately my z parameter is a dose parameter that increases over time depending on a certain number of other parameters and from the running time of my simulations too so I cannot use that tool...
any idea?
Lorenzo
any idea?
Lorenzo
Unfortunately, it looks like the easiest option might be to build an external function to do this (using the GNU Scientific Library).
Thank you... unfortunately for me I'm a newbie of programming and have no idea of GNU Scientific Library so it would be very nice of you if you could give me some details, examples and references on how to proceed in Vensim PLE.Administrator wrote:Unfortunately, it looks like the easiest option might be to build an external function to do this (using the GNU Scientific Library).
All the best.
Lorenzo
External functions cannot be implemented in PLE.
Gosh... any shortcut for solving my problem?Administrator wrote:External functions cannot be implemented in PLE.
Lorenzo
I've already suggested trying to replicate the function using the GSL source files, this is all you can do in PLE.
I remember but you too should remember that I asked you some more details on how to proceed and I'm still waiting...Administrator wrote:I've already suggested trying to replicate the function using the GSL source files, this is all you can do in PLE.
Lorenzo
Search Google fpr GSL 1F1, this will give you the source code. Try and replicate this in Vensim.lorenzo.cioni wrote:Administrator wrote:how to proceed and I'm still waiting
The difference between the hypergeometric distribution and the binomial distribution is drawing without vs. with replacement.
So, as long as the populations N and K are large with respect to the number drawn n, or n = 0 or 1, you can get a close approximation with RANDOM BINOMIAL.
This will generally be true as long as TIME STEP is small with respect to the time scale of the infection process.
Hi tomfidtomfid wrote:The difference between the hypergeometric distribution and the binomial distribution is drawing without vs. with replacement.
maybe there is a misunderstanding... I'm talking about an hypergeometric function and not distribution: are you sure they are the same thing?
Anyway thank you a lot.
Lorenzo
I have searched and I've found that the funciotn is implemented through a routine called gsl_sf_hyperg_1F1 but I was able to find only references in pdf files but no source code, could you please be more precise?Administrator wrote:Search Google fpr GSL 1F1, this will give you the source code. Try and replicate this in Vensim.lorenzo.cioni wrote:Administrator wrote:how to proceed and I'm still waiting
Thank you a lot.
Lorenzo
A curiosity: any relation with gamma functions/distributions?lorenzo.cioni wrote:I have searched and I've found that the funciotn is implemented through a routine called gsl_sf_hyperg_1F1 but I was able to find only references in pdf files but no source code, could you please be more precise?Administrator wrote:Search Google fpr GSL 1F1, this will give you the source code. Try and replicate this in Vensim.lorenzo.cioni wrote:
Thank you a lot.
Lorenzo
L.
No (I had never heard of the function before you posted today).lorenzo.cioni wrote:could you please be more precise?
I found the GNU Scientific Library when searching for 1F1. All I can suggest is downloading the source code and searching it.
Ok, thank you a lot.. at the ned I found the code but I'm 99% sure it cannot be used within Vensim without defining an external function and this definitely excludes the PLE version of the program....Administrator wrote:No (I had never heard of the function before you posted today).lorenzo.cioni wrote:could you please be more precise?
Lorenzo
Ah ... I think the function is just a generalization of the series that appears in the pdf of the distribution. Seems like you should be able to implement the integral representation here,
http://mathworld.wolfram.com/ConfluentH ... tKind.html
because Vensim has the log Gamma function. (Maybe not in PLE though.)
What the heck are they using this for?
Hi tomfittomfid wrote:Ah ... I think the function is just a generalization of the series that appears in the pdf of the distribution. Seems like you should be able to implement the integral representation here,
if I understand you well you are referring to relation (3). Are you sure it can be implemented in a Vensim model?
Lorenzo
Tomfid, sorrylorenzo.cioni wrote:Hi tomfittomfid wrote:Ah ... I think the function is just a generalization of the series that appears in the pdf of the distribution. Seems like you should be able to implement the integral representation here,
Lorenzo
No problem.Tomfid, sorry
I'm not 100% certain, but the integral breaks up to terms with e^x, xe^x, and x^2e^x, so it should be solvable. The gamma function may be a problem in PLE though.
Hi Tomfidtomfid wrote:No problem.Tomfid, sorry
I was able to find this nice calculator
so I will get a set of points of my dependent variable P having fixed the values of a and b and having only z vary over a certain set of values so to be able to implemet my function with a lookup in Vensim with z (the dose) as the only independent variable.
Thank you a lot (and to Adminisrtator too, of course) for having devoted part of your time and efforts to help me.
Lorenzo
PS I'll let you know....
could you please check the attached model and explain the seemingly absurd behavior of the 1F1 variable through which I'm trying to implement the infinite series expression of such the 1F1 Hypergeometric function?
How many terms should I consider? Is there any better and more clever way (in Vensim, of course)?
All the best.
Lorenzo
All the best.
Lorenzo
- ModelloDoseResponseQMRA14112017TempoIndipendenteParametriCostantiNoDistribuzioni.mdl
- (15.54 KiB) Downloaded 136 times
