Hi every one
I have a question about vensim:
I have use the condition function that if X in the time series=Max, then X+b, X
X is the number in the time step
How i can do this?
the attached pic my concept
thanks a lot
Question
- Vensim version: PLE
Question
- Capture.JPG (37.56 KiB) Viewed 2893 times
Re: Question
If N is a proxy for time here, there are two answers.
1. If the maximum is taken over all time, this is acausal (except at the end of the run), i.e. it implies knowledge of the future, which is impossible both in reality and in the model.
2. If what you mean by MAX is the largest value encountered so far at time t, then it's possible. You could do the following:
maximum x = SAMPLE IF TRUE( x > maximum x, x, x)
y = IF THEN ELSE( x >= maximum x, x+b, x )
Re: Question
Hello
thanks for your reply
this function did not work properly
I want do this (attached Pic)
It is worth mentioning that I use free version (Vensim PLE)
I 'll thank you to guide me .
- Capture.JPG (35.45 KiB) Viewed 2875 times
Re: Question
Try the attached model.
Re: Question
my goal that max A in total A time series select, in this time series A is 13.97
Re: Question
Please help me to solve this problem
Re: Question
The demo model I uploaded does give you the maximum value.
