Hi there,
I am trying to import Excel file into vensim- My data is hourly electricity consumption in a year. when I import the values it sorts the data out in hours - Meaning all the 00:00s together followed by 01:00s, 02:00s and so on till 23:00- But it messes my calculation as I try to simulate the changes through the day (hourly)
Please see the attached file - Vensim sort the data out as all the 0s first then 1s and so on can I make changes to that?
How can I have my Hourly Data (For a year) following day after day in a Vensim ? showing the (00:00 to 23:00)1st Jan 2011followed by (00:00 to 23:00) 2nd Jan 2011 and so on for a year.
Best regards,
Bahar
Importing Data from Excel (24 hours in a year)
- Vensim version: PRO
- Excel Data.docx
- (31.25 KiB) Downloaded 173 times
Re: Importing Data from Excel (24 hours in a year)
My guess is it's the conversion between Excel date/time and integer not working correctly.
Can you upload the spreadsheet? It's impossible to help when we've only got screenshots. And are you importing using GET_XLS_LOOKUPS or actually importing the sheet?
You might also want to look at the decimal values of your time entries, they are almost certainly all less than zero. You'll need to convert these into 1, 2 etc to use them properly.
Thanks for the respond. Please find the files attached. Well I am still not clear what should I do. Sorry I am new to vensim and this is my 1st model.
Thanks,
Bahar
Thanks,
Bahar
- Solar Radiation- Sample.xlsx
- (11.76 KiB) Downloaded 165 times
- Wind Speed Table.xlsx
- (22.3 KiB) Downloaded 168 times
- Consumption.xlsx
- (21.99 KiB) Downloaded 166 times
HI again,
I am actually Import the data from lookup -in the equation.
Bahareh
Bahareh
You can't directly import a 2-dimensional table like your solar radiation table, except as an array of constants.
Some options:
1. Import the table as an array with GET XLS CONSTANTS, and then use rows of it with VECTOR LOOKUP
2. Using copy-paste, create a separate lookup table each for Jan, Feb, Mar ... You can either make each one a separate named variable, or use an array dimension, as in:
MonthOfYear : Jan, Feb, ...
Insolation[Jan] (0,0),(0,0), ...
Insolation[Feb] (0,0),(0,0), ...
3. Reorganize the table so that there's a single time index from start to finish.
Normally, I would choose option 3 for time series data. However, I think 1 or 2 is the more natural choice here.
Some options:
