Strange Problem: Missing Model
- Vensim version: PLE
I have been working long time to generate a model. This model have been saved into several different versions (increment change in each model). I always back up my file in google drive stream, and have no problem. Recently I changed my computer from Asus S400 to Dell G3, and that's when the problem started to occured.
This is the first time I using vensimPLE in my new computer.
After I finish editing a model, then I saved and shut down my computer. After a while, I wanted to continue to work on my model, but when I open my last saved file it was blank. Similar condition to when we open new model in vensim. There is no variable, time step was not set yet, and no graphic that I was made before. It was strange, because from file size, I know that file still contained model information from my last work. Even, when I opened .mdl in text editor, the equation is still there.
In desperation, I tried to restart, uninstall and install vensim again. But the result still same. Right now I'm stuck. Any advice? Please help me.
Thank you in advanced
Details: VensimPLE 7.2a (single precision) running on windows 10
- SFD Smelter 6 Cu Cek.mdl
- (43.38 KiB) Downloaded 185 times
Re: Strange Problem: Missing Model
Can you let me know which edition of Windows 10 you are using?
Thank you for the reply.
I'm using Microsoft Windows 10 Home Single Language 64-bit
Version 10.0.16299 Build 16299
ok. I was hoping it was the enterprise version of Windows.
Can you try creating a shortcut as detailed in the attachment? The INI file for Vensim PLE is venple.ini (not vensim.ini).
- Vensim shortcut instructions.docx
- (421.91 KiB) Downloaded 191 times
I've tried what you have suggested.
I was okay in opening older model
But, when I opened my last saved file (the one that I sent) it still give me blank model (picture attached).
- blank model
- vensim4.PNG (125.17 KiB) Viewed 5906 times
- .ini file and vensim PLE shortcut in my document folder
- vensim3.PNG (72.59 KiB) Viewed 5906 times
- Edited shortcut target
- vensim2.PNG (18.65 KiB) Viewed 5906 times
Did you double click the model, or click File->Open in Vensim?marco_savoia wrote: ↑Mon Sep 03, 2018 2:55 pm I've tried what you have suggested.
I tried both. But similar result
Try moving the file out of the Google Drive hierarchy? Drive causes problems with locked .vdfs, though that shouldn't affect an mdl.
Okay, I have moved the model to desktop folder and tried to double click the model and using File -> Open model.
Nothing changed, the model still gave blank page
I have access to vensim DSS in my campus laboratory.
If I opened using vensim DSS, is it gonna solve the problem?
Ahh, I think your original model is corrupted. Try this one.
- (43.38 KiB) Downloaded 191 times
Thank you very much!!!
It works!
Can you explained to me what was happened?
So I can prevent this situation from happening again
It works!
Hard to say. I've had problems with both Google Drive and OneDrive syncing back an older version of a file on top of my current work (powerpoint, not Vensim). Could be related.
Okay, thank you for your help.
I have take my file off from google drive synchronization
