Sensitivity graph's Vertical Axis setting
Posted: Sat Oct 06, 2018 4:27 am
by yut
Hi there,
I would like to specify the maximum and minimum of the vertical axis of sensitivity graphs.
Could anyone give me how to set it?
In my case, Sensitivity Graph's default setting is that maximum is 500, but I would like to set it to 500.
Thanks in advance.
Re: Sensitivity graph's Vertical Axis setting
Posted: Sat Oct 06, 2018 1:58 pm
You can control that with a Custom Graph: https://www.vensim.com/documentation/23995.htm
A custom graph is basically a normal graph with the :CONFIDENCE keyword added to provide confidence bounds. https://www.vensim.com/documentation/24000.htm
Posted: Mon Oct 08, 2018 11:41 pm
by yut
Hi Tom,
Thanks so much!
I succeeded in it.
