Estoy ejecutando un modelo de dinamica de sistemas en matlab y me sale este error:
Warning: Message from C preprocessor:
lcc preprocessor error: C:\Users\Public\Vensim\DLL\vendll.h:5
Could not find include file "vendllerr.h"
> In loadlibrary at 321
In LoadVensimLibrary>LoadLibrary at 10
In LoadVensimLibrary at 2
In Start at 26
Warning: Warnings messages were produced while parsing. Check
the functions you intend to use for correctness. Warning text
can be viewed using:
[notfound,warnings]=loadlibrary(...)
> In loadlibrary at 347
In Start at 26
Warning: The data type 'error' used by function
vensim_tool_command does not exist.
> In loadlibrary at 406
In Start at 26
vensim_show_sketch does not exist.
In Start at 26
Warning: The function 'vensim_get_run_info' was not found in the
library
In Start at 26
vensim_set_parent_window does not exist.
In Start at 26
VensimCToolCommand does not exist.
In Start at 26
Warning: The data type 'error' used by function VensimCShowSketch
does not exist.
In Start at 26
VensimCSetParentWindow does not exist.
In Start at 26
Error using RunModel (line 69)
Vensim is not in an active simulation
Error in Start (line 43)
RunModel(SimYears, S(i), Region(r), Folder, m, saveList);
me podrian decir porque?
matlab
Re: matlab
I've attached vendllerr.zip (which contains vendllerr.h).
- vendllerr.zip
- (719 Bytes) Downloaded 202 times
Re: matlab
ok gracias. yo tengo otro modelo en vensim y quiero leer algunas variables de mi modelo pero no lee, corre el vensim pero a la hora de leer aparece cero en la ventana de matlab.
Re: matlab
There are some threads on this forum that mention Matlab. I do not have a copy so cannot offer any advice.
