Working with Levels in Vensim
Posted: Wed Aug 21, 2019 1:51 pm
I noticed, while I was working on a Vensim Model, that levels (even when changing the integrators) calculate and shows the stock variation in a specific day n up till the day n-1.
Let me explain, if a rate pointing towards a level with a certain value x in a specific day n, this value will appear in the level the next day (n+1).
Now I need to change this a little bit. I need the changes (in production for my own model) to appear and be considered in the calculation for the same day.
I have been stuck with this detail fore some time. Can you suggest a solution?
Thank you in advance
