Converting flow into lookup
baleceka
Post by baleceka »
Hey guys
I created a hubbert production model, the results is in the rate. I want to use it as lookup time as function of "hubbert production(time)" on a level variable
But then this message appear:
hubbert production is used but not defined as lookup
https://drive.google.com/file/d/1zkmUk7 ... sp=sharing
Any idea on how to deal with this?
When I just type on that level variable as hubbert, it continously accumulating while I need it as a function of time
Thank you
Re: Converting flow into lookup
I can't view the model remotely, but you probably just need to change the type of the variable to "lookup".
See:
https://vensim.com/lookups-in-vensim/
http://vensim.com/documentation/usr08.htm
