Time Bound in Model Setting
husnafezaahmad
Post by husnafezaahmad »
Hello & Top of the day everyone,
i have this problem where i want to model my electricity supply industry market but i have issue with time bound setting for the model setting :(
for the overall model, it supposed to be in a yearly time setting, but throughout the calculations, there are some parts that needs hourly setting.
I really need some enlightment from any of you.
Thank you in advance :oops:
Re: Time Bound in Model Setting
I'm not sure exactly wray you are asking for help with.
If you want to change the x axis, take a look at the time base function. This leaves the model running in years, but you can display graphs using hours on the x axis.
husnafezaahmad
I know my question is not that clear. Sorry for that.
OK the problem is this.
So, the whole set of the model has to be in yearly setting 'cause i basically want to make it a planning model.
But only at the "Wholesale Market" box, the calculation in it, has to be done base on hourly calculation.
So, do i have to make 2 models, and merge it OR is there any other way?
If let say i have to make 2 separate models for the whole model and also the "Wholesale Market", how do i merge the 2 models?
Again, thanks so much in advance.
You guys' helps are much needed.
p/s: photo credited to owner.
Administrator wrote: Sun Feb 02, 2020 2:45 pm I'm not sure exactly wray you are asking for help with.
husnafezaahmad
I guess this one is something that i can look into.
Thankss!!
husnafezaahmad
Tried this one, but i couldn't relate :(
Attached is my file.
Please someone help me.
Load Demand Curve.mdl
(3.05 KiB) Downloaded 168 times
It will be easier for anyone to hep you if you correct first the unit errors in th model uploaded, a fundamental basic of SD.
Regards
husnafezaahmad
Sorry i didn't realise that i uploaded the wrong file.
Tbh, i am very new with this Vensim. Hence kinda lost with it.
