Question about deleting previous runs
Posted: Fri Mar 06, 2020 10:03 am
by RWTH_FCN
I have run model several times and since dataset are huge I want to delete them. To do so, I should go in Windows->Control panel->Datasets. The problem is that I can not delet them and they stay here. Do you have any ideas why it heppens?
Re: Question about deleting previous runs
Posted: Fri Mar 06, 2020 10:15 am
What version of Vensim are you using?
You can always delete them manually as well by browsing to the folder where they are stored.
Posted: Fri Mar 06, 2020 10:26 am
by RWTH_FCN
Administrator wrote: ↑Fri Mar 06, 2020 10:15 am
Version 6.4. Actually, when I want to delete them manually I get an error that they cannot be deleted becasue file is open in Vensim. So, I decided to remove them in Vensim but it is not possible in Vensim as well.
Posted: Fri Mar 06, 2020 10:37 am
If you close Vensim, you will be able to delete them manually.
Posted: Fri Mar 06, 2020 10:41 am
by RWTH_FCN
Administrator wrote: ↑Fri Mar 06, 2020 10:37 am
Ah, you are right. thanks
