I right clicked on the Graph and under the Graph Options I selected Activate on variable selection. When I was closing the Vensim it asked "Do you want to save the Analysis Toolset?" and I saved in the suggested location (C:\Program Files\Vensim). However, after opening Vensim again, the setting is was changed back to the defaults. I checked several times and faced the same behavior. What should I do?
Customized Analysis Toolset
Re: Customized Analysis Toolset
Try saving to a different location. C:\Program Files\Vensim will not be writable by Vensim.
Thanks for your answer. I saved on the Desktop. But the problem is that Vensim does not load that saved file settings in the next start.
I am confident that it was normally working in the previous versions. Now I am on 8.0.9.
I agree - this worked until very recently. We'll have a fix soon.
