Alternative to duplication of stock and flow sections
Posted: Tue Jun 09, 2020 7:07 am
by Ferenc DV
Hello Everyone,
I am using Vensim PLE+. I have a portion of a Stock and Flow model that I need to duplicate for multiple parallel input flows. Is there a way I can just use an array for one model, so that the flow occurs in parallel, rather than duplicating the models for each stream. The example is distribution of stock to multiple locations where the structure of the Stock and Flow model for each stream is duplicated.
Thanks,
Ferenc
Re: Alternative to duplication of stock and flow sections
Posted: Tue Jun 09, 2020 8:13 am
Not using PLE+. You would need Pro/DSS for array (subscripting) functionality.
