Vensim ODBC scenario selection via run name
Posted: Mon Jun 29, 2020 3:39 am
Saw on https://www.vensim.com/documentation/va ... enario.htm that one can refer to the name of the current Vensim simulation run by using the character (!).
Therefore if one has the below ODBC query, can one actually send the scenario name in the form of the character (!) to the select statement?
More specifically wondering if this part of the SQL code "AND
IN ('STEPS')" can be changed to use ! and automatically get the name of the scenario from the run name.
Tried it but doesn't seem to work, so wanted to see if others had experience with this?
:DATA
:VARNAME=[Code FLOW]
:SUB=[Code PRODUCT]
:SUB=[Code REGION]
:TIME=[YEAR]
:VALUE=[VALUE]
:SELECT DW
WHERE [Code FLOW] IN ('BASEDECLINE')\
AND [Code UNIT] IN ('DECIMAL')\
AND [Code PRODUCT] IN ('GAS')\
AND [Code CATEGORY] IN ('ENERGY')\
AND [Code PUBLICATION] IN ('2020ED')\
AND [Code SCENARIO] IN ('BASE')
Thanks, Pawel
