Combine output
husnafezaahmad
Combine output
Post by husnafezaahmad »
Hello all!
I'm back with another confusion in my life with Vensim :cry: :cry:
Screen Shot 2020-11-24 at 15.02.25.png (309.15 KiB) Viewed 2361 times
How do i combine all outputs into one matrix/under one variable? But i do not want it to be accummulated.
Please send me some help. Thanks in advance.
Re: Combine output
It might have been much easier to do this with subscripts, all the structures look identical so subscripts would have been perfect.
If you upload the model, it should be easy to demonstrate how to do this.
husnafezaahmad
Re: Combine output
Administrator wrote: Tue Nov 24, 2020 4:45 pm It might have been much easier to do this with subscripts, all the structures look identical so subscripts would have been perfect.
But i've learnt that we can only have up to 8 subscripts.
Please enlight me on this, Admin. Here is the model.
combine.mdl
(15.43 KiB) Downloaded 135 times
Re: Combine output
You can have as many subscript ranges as you want, and a particular range can have a large number of elements. The only limit is that a particular variable can't have more than 8 subscript ranges. I don't think I've ever seen more than 5 or 6 in a real model.
Re: Combine output
If you have unsubscripted variables that you want to combine, you can do something like the following:
item : a,b
price a = 10
price b = 20
price[a] = price a
price = price b
revenue[item] = price[item]*quantity[item]
http://www.vensim.com/documentation/21265.htm
Sometimes it's useful to have the explicit visual layout, as in your example model, but in this case it seems much easier to dispense with the individual variables and use subscripts throughout.
husnafezaahmad
Re: Combine output
Thanks a lot, Tom & Admin.
Tried the solutions suggested, and i get to do what exactly i want to do.
But now i encountered another problem which is, an error put as "Arguments out of range in VECTOR SORT_ORDER".
What does that means?
Re: Combine output
Look at the help system for vector sort order (it has an example on how to use the function). My guess is that you have one of the arguments wrong.
