Sensitivity Data
johnjohnson4
Vensim version: PLE+
Sensitivity Data
Post by johnjohnson4 »
I am running a sensitivity analysis with PLE Pluse. I am trying to export the variable data (input and output) for each scenario. For example, I have four input variables that vary randomly from 1-10. I am tracking two output variables. I want to export each multivariate combination and the corresponding outputs for 200 simulations.
I am able to export the output variables, but I can't figure out how to get the corresponding multivariate combinations.
Thanks in advance for your help
Re: Sensitivity Data
Do you have the variables in the save list that you want to export?
johnjohnson4
Thanks for your reply. Yes. All four input variables are in the Savelist.
Do you have a sample, or can you .zip up the model and supporting files?
The default export should include both the output variables and the input parameters from the .vsc file.
johnjohnson4
Here is the model. Thanks for giving it a look. If you run the Sensitivity function all of the variables are already selected.
I4.0_Ship Repair_S&F_02152021F-5_Experiment Data.zip
(8.24 KiB) Downloaded 177 times
The .zip seems to be missing the .vsc and .lst files?
johnjohnson4
Sorry about that. Attached are:
1) I4.0_5.0_Experiments.vsc
2) TechFactorExperiment_Input_Output.lst
3) I4.0_Ship Repair_S&F_02152021F-5_Experiment Data.mdl
I4.0_Ship Repair_S&F_02152021F-5_Experiment Files.zip
(8.74 KiB) Downloaded 182 times
One problem is that you have a colon in your run name. Colons are illegal file system characters, so that breaks naming the dataset. We'll have to disallow those and a few other characters I guess.
After deleting the colon, I can run and export the sensitivity results to yield:
Simulation	Tech Factor: Adj Time for Efficiency Impact""	Tech Factor: Cost""	Tech Factor: Efficiency Fractional Rate""	Tech Factor: New Business""	Port City Jobs	ROI
1	2.135618875	1.12322795	7.044533483	4.612675317	115320.5959	100
2	14.34797783	2.626708798	1.8172899	7.52753672	700102.7978	99.4391724
3	8.60677939	4.772745214	2.285229625	4.54597021	193676.7468	99.77060124
4	15.94191306	6.040241197	8.737766876	6.943789773	236468.1576	99.04659886
johnjohnson4
How do you create that report? That looks like exactly what I am trying to do!
johnjohnson4
I think I have it! Under the Model tab, Export Dataset. Thank you very much for your assistance. I really appreciate it.
v/r,
john
Sorry - should have mentioned that explicitly! Glad it's working. We're hoping to roll some capability for visualizing this into native Vensim soon.
