Installation Error Code 977
Hi! I would like to using Vensim PLE, but I can't install successfully after downloading the Installation package. The error statement is the following:
“Resource file comes from a different version of Vensim(002)”
"Reinstall Vensim(error 977)"
My Installation info:
System: Window 10 x64
System Language: Chinese
Installation path: default
Usage: Academic use, very first time installation
Appreciate your support!
Re: Installation Error Code 977
Try downloading again, and make sure you right click on the newly downloaded installer and select "Run as administrator".
Thanks for your reply, but I tried and fail too with the same error, It there any previous version package link available to test?Administrator wrote: ↑Tue Sep 14, 2021 2:12 pm Try downloading again, and make sure you right click on the newly downloaded installer and select "Run as administrator".
Appreciate!
What version of Vensim are you downloading (32 or 64 bit)?
This error usually happens when Vensim has not been installed using administrative permissions.
Hi! I have tried using administrative permissions, but same error happens. I am using 64 version. It is possible to have a previous, for example, 8.2.1 version installation package to try? Thanks!Administrator wrote: ↑Tue Sep 14, 2021 2:46 pm This error usually happens when Vensim has not been installed using administrative permissions.
I've just tested the installer, it's working without any problems.
Try deleting everything in the following folder and installing again.
C:\Users\Public\Vensim\PLE
Unfortunately this doesn't work either, will the previous installation package will help?Administrator wrote: ↑Tue Sep 14, 2021 3:07 pm I've just tested the installer, it's working without any problems.
If you download the Windows 7 version, this is a older installer.
Hi, New problem with this one: Error during installation: Do not change the installation file name.Administrator wrote: ↑Tue Sep 14, 2021 3:37 pm If you download the Windows 7 version, this is a older installer.
Could it be any conflict between softwares?
Try disabling your anti virus, that is likely causing this new problem.
Thanks for your reply, I will make more attempts!Administrator wrote: ↑Tue Sep 14, 2021 4:07 pm Try disabling your anti virus, that is likely causing this new problem.
