Issue with publishing to web
Bayasgalan
Post by Bayasgalan »
same issue with web publisher. I stuck here. can someone help me please?
Re: Issue with publishing to web
Same advice as when you emailed us. Start with a working model. You cannot publish to the web if your model does not work in Vensim.
You also need to fix the error where you are using a lookup table as a number. See the parameter "дээд боловсролын сургууль завсарлалтын дундаж", this is passing a lookup table to a lookup table (you cannot do this).
Bayasgalan
it is same, when I try simple model. Same result. First I want to publish small model to web
Where have you uploaded the files to a server?
Bayasgalan
Local server and i can't find mdl.js and mdl.wasm
Can you upload the model you are trying to publish?
When you publish, can you paste the output of the emscripten window showing the errors?
Bayasgalan
that is the error, when I try to publish.
C:\Users\dell\Documents>REM First set the WASM environment variables.
C:\Users\dell\Documents>call C:\Users\Public\Vensim_DSS\COMP\wasm\emsdk\emsdk activate latest
Resolving SDK alias 'latest' to '2.0.30'
Resolving SDK version '2.0.30' to 'sdk-releases-upstream-c69458f1bbf3ef5b8da4e934de210659cc9bca04-64bit'
Setting the following tools as active:
node-14.15.5-64bit
python-3.9.2-1-64bit
java-8.152-64bit
Adding directories to PATH:
PATH += C:\Users\Public\Vensim_DSS\COMP\wasm\emsdk
PATH += C:\Users\Public\Vensim_DSS\COMP\wasm\emsdk\node\14.15.5_64bit\bin
PATH += C:\Users\Public\Vensim_DSS\COMP\wasm\emsdk\upstream\emscripten
Setting environment variables:
PATH = C:\Users\Public\Vensim_DSS\COMP\wasm\emsdk;C:\Users\Public\Vensim_DSS\COMP\wasm\emsdk\node\14.15.5_64bit\bin;C:\Users\Public\Vensim_DSS\COMP\wasm\emsdk\upstream\emscripten;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;C:\Windows\System32\OpenSSH\;C:\Program Files\Git\cmd;C:\Users\dell\AppData\Local\Programs\Python\Python39\Scripts\;C:\Users\dell\AppData\Local\Programs\Python\Python39\;C:\Users\dell\AppData\Local\Microsoft\WindowsApps
EMSDK = C:/Users/Public/Vensim_DSS/COMP/wasm/emsdk
EM_CONFIG = C:\Users\Public\Vensim_DSS\COMP\wasm\emsdk\.emscripten
EMSDK_NODE = C:\Users\Public\Vensim_DSS\COMP\wasm\emsdk\node\14.15.5_64bit\bin\node.exe
EMSDK_PYTHON = C:\Users\Public\Vensim_DSS\COMP\wasm\emsdk\python\3.9.2-1_64bit\python.exe
JAVA_HOME = C:\Users\Public\Vensim_DSS\COMP\wasm\emsdk\java\8.152_64bit
Clearing existing environment variable: EMSDK_PY
The changes made to environment variables only apply to the currently running shell instance. Use the 'emsdk_env.bat' to re-enter this environment later, or if you'd like to permanently register this environment permanently, rerun this command with the option --permanent.
PATH = C:\Users\Public\Vensim_DSS\COMP\wasm\emsdk;C:\Users\Public\Vensim_DSS\COMP\wasm\emsdk\upstream\emscripten;C:\Users\Public\Vensim_DSS\COMP\wasm\emsdk\node\14.15.5_64bit\bin;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;C:\Windows\System32\OpenSSH\;C:\Program Files\Git\cmd;C:\Users\dell\AppData\Local\Programs\Python\Python39\Scripts\;C:\Users\dell\AppData\Local\Programs\Python\Python39\;C:\Users\dell\AppData\Local\Microsoft\WindowsApps
Could Not Find C:\Users\dell\Documents\web\mdl.js
Could Not Find C:\Users\dell\Documents\web\mdl.wasm
A subdirectory or file web already exists.
emcc: warning: EXTRA_EXPORTED_RUNTIME_METHODS is deprecated, please use EXPORTED_RUNTIME_METHODS instead [-Wdeprecated]
wasm-ld: error: C:\Users\Public\Vensim_DSS\COMP\wasm\vensim_wasm.bc: unexpected table definition(s) without corresponding symbol-table entries.
emcc: error: 'C:/Users/Public/Vensim_DSS/COMP/wasm/emsdk/upstream/bin\wasm-ld.exe -o web\mdl.wasm C:\Users\dell\AppData\Local\Temp\emscripten_temp_hzzlgmmh\mdl_wasm_0.o C:\Users\Public\Vensim_DSS\COMP\wasm\vensim_wasm.bc -LC:\Users\Public\Vensim_DSS\COMP\wasm\emsdk\upstream\emscripten\cache\sysroot\lib\wasm32-emscripten --whole-archive -lfetch --no-whole-archive -lGL -lal -lhtml5 -lc -lcompiler_rt -lc++-noexcept -lc++abi-noexcept -ldlmalloc -lc_rt_wasm -lsockets -mllvm -combiner-global-alias-analysis=false -mllvm -enable-emscripten-sjlj -mllvm -disable-lsr --import-undefined --strip-debug --export-if-defined=GetNumberOfSubscriptElements --export-if-defined=GetConstant --export-if-defined=AddCINFile --export-if-defined=GetSeries --export-if-defined=SetDebugModeOff --export-if-defined=GetValueAtTime --export-if-defined=SetDebugModeOn --export-if-defined=DumpResultstoStdOut --export-if-defined=DumpResultsToDisk --export-if-defined=InitializeModel --export-if-defined=IsVensimLoaded --export-if-defined=RunSim --export-if-defined=main --export-if-defined=GetTimeSeriesNumVals --export-if-defined=FindLookup --export-if-defined=Get_LookupName --export-if-defined=Get_NUM_AUX --export-if-defined=Get_NUM_DELAYS --export-if-defined=Get_NUM_LEVELS --export-if-defined=Get_NUM_LOOKUPS --export-if-defined=Get_NUM_VARS --export-if-defined=Get_VarName --export-if-defined=Get_VarType --export-if-defined=GetConstantUsingIndex --export-if-defined=GetConstantUsingVarName --export-if-defined=GetNumVariables --export-if-defined=GetVariableIndex --export-if-defined=GetVariableName --export-if-defined=GetVariableType --export-if-defined=SetConstant --export-if-defined=SetLookup --export-if-defined=emscripten_stack_get_end --export-if-defined=emscripten_stack_get_free --export-if-defined=emscripten_stack_init --export-if-defined=stackSave --export-if-defined=stackRestore --export-if-defined=stackAlloc --export-if-defined=__wasm_call_ctors --export-if-defined=fflush --export-if-defined=__errno_location --export-if-defined=malloc --export-if-defined=free --export-if-defined=__start_em_asm --export-if-defined=__stop_em_asm --export-table -z stack-size=5242880 --initial-memory=268435456 --no-entry --max-memory=2147483648 --global-base=1024' failed (returned 1)
"Batch file complete!"
Press any key to continue . . .
The model? Does the model you are trying to publish actually simulate?
Bayasgalan
Just simple model I try to publish.
stock.mdl
(1.61 KiB) Downloaded 286 times
Can you try editing your wasm_compile.bat file and find the line
call %3emsdk activate
and replace it with
call %3emsdk activate sdk-2.0.6-64bit
Bayasgalan
there is no error, but still same result. Can you see what is wrong this?
C:\Users\dell\Documents>call C:\Users\Public\Vensim_DSS\COMP\wasm\emsdk\emsdk activate sdk-2.0.6-64bit
Resolving SDK version '2.0.6' to 'sdk-releases-upstream-4ba921c8c8fe2e8cae071ca9889d5c27f5debd87-64bit'
node-14.15.5-64bit
java-8.152-64bit
PATH = C:\Users\Public\Vensim_DSS\COMP\wasm\emsdk;C:\Users\Public\Vensim_DSS\COMP\wasm\emsdk\node\14.15.5_64bit\bin;C:\Users\Public\Vensim_DSS\COMP\wasm\emsdk\upstream\emscripten;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;C:\Windows\System32\OpenSSH\;C:\Program Files\Git\cmd;C:\Users\dell\AppData\Local\Programs\Python\Python39\Scripts\;C:\Users\dell\AppData\Local\Programs\Python\Python39\;C:\Users\dell\AppData\Local\Microsoft\WindowsApps;
PATH = C:\Users\Public\Vensim_DSS\COMP\wasm\emsdk;C:\Users\Public\Vensim_DSS\COMP\wasm\emsdk\upstream\emscripten;C:\Users\Public\Vensim_DSS\COMP\wasm\emsdk\node\14.15.5_64bit\bin;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;C:\Windows\System32\OpenSSH\;C:\Program Files\Git\cmd;C:\Users\dell\AppData\Local\Programs\Python\Python39\Scripts\;C:\Users\dell\AppData\Local\Programs\Python\Python39\;C:\Users\dell\AppData\Local\Microsoft\WindowsApps;
Bayasgalan
wasm_compile.bar file's picture, when I open this file
When you made the change and tried publishing from Vensim, it looks like it worked successfully. Do you have a mdl.wasm in the web sub-folder of your model? If yes, what is the address where you uploaded it to the web?
