units check errors
units check errors
Hello, I want to ask what this unit error means?The error screenshot is in the attachment
- 11121543.mdl
- (37.99 KiB) Downloaded 104 times
- errors.png (71.1 KiB) Viewed 1555 times
Re: units check errors
I suspect this is due to the use of DELAY1 with numerical parameters. For example, if you use DELAY1(input, 3, 0), the 3 and 0 don't have units. If instead you use DELAY1(input, delay time, 0) the time constant is properly dimensioned. This is also essential good practice, because it exposes the delay to sensitivity analysis or other testing.
Hello, do you mean that my DELAY1 function is wrong? Is it because my unit does not define synonyms? Can you tell me how to solve this unit error in the figure?
- 1116.png (63.14 KiB) Viewed 1526 times
I'd suggest doing one of the many Vensim tutorials such as the one below. They will teach you how to define units.
On this page you will find a really good Vensim PLE tutorial.
Thank you, I will take this tutorial.
I'm handicapped by not knowing the language, but it looks like you have two time units going - one given by the character in the denominator in the units expressions in the error message, and "day".
