Copy past problem
Copy past problem
I'm not able to copy and past model components from one mdl.file to another mdl.file (using PLE-PLUS).
I selected the components to be copied (excluding the shadow variables), copied them and finally unsuccesfully tried to past them on an empy view page.
Could you please advise me on this problem.
Kind regards, Joaquim
Re: Copy past problem
Are you on Windows or Mac?
And in the new or old GUI?
I'm on Windows ; I use a Vensim PLE version of 2020 and have not downloaded a new GUI since then
What is the exact version of Vensim you are using?
You can find that under Help>About Vensim
Another consideration: are you copying within one application instance, or launching two?
Is this the right version info?
PLE Plus 7.3.5 (Single Precision) *32
7.3 is actually ~2018 - there's probably not much we can do about that if there was a bug.
Per my previous question, copying between application instances could be problematic. You may need to open the model, copy, close, open the destination, and paste, within a single instance of Vensim.
Can I upgrade to the most recent Vensim version with my current PLE-Plus license and still run my models? I assume that this would solve the copying problem
If so, which steps should I follow?
To upgrade, visit the following site and log in using your licence details. The most up to date version you are entitled to will be displayed.
https://www.vensim.com/php-bin/VSUK/Cus ... index.html
I tested to verify that copy/paste is working fine in forthcoming 9.2 (it is). However, the single-application-instance limitation does still exist.
