With a usable DLL I get an error when I use 'check model' in Vensim.
error: missing a closing parenthesis on a lookup table call
parameters
ACLSD[DCCT,DSCP,BSNS]=INITIAL(OPENWF(DCAT,DISC,DEPT,MODEL,1,2,RUNOP[OLS1],
OLIST,RECLN,RUNNO))~ ND ~|
The error is located after the first argument in the subprogram OPENWF. That equation is the first in the model.
Please tell me how to correct this error.
Error when using 'check model'
Re: Error when using 'check model'
I've already given you instructions on what to do here via email.
The DLL is not usable, you need to rebuild it with double precision enabled (define DBLPREC).
The DLL was 'usable' in the sense of being error-free in Visual Studio terms. I was previously unaware that 'check model' is governed by DBLPREC.
The precision of the dll has to match the precision of the Vensim version in use. All Vensim versions are now double precision.
