A few other issues:
1. I have a 14-inch MacBook and I think this window was designed on a larger display because every time I have to resize it to get to the ‘Simulate’ button. The window size is restarted every time I close it.
- Screenshot 2024-05-02 at 10.04.30 AM.png (430.45 KiB) Viewed 633 times
2. The tools in the analysis toolset (like graph, table, sensitivity graph, etc.) can be embedded in the menu bar. Ideally, they can have shortcuts based on the operating system (e.g., ⌘/Control + Shift + G shows the graph for the selected variable). This would be handy when switching between multiple tools quickly (e.g., looking at the graph, table, and statistics, sequentially for different variables). Even if shortcuts are not defined by default, users can assign their customized shortcuts (at least on macOS), but having them in the menu bar is required.
3. It would be extremely helpful if the same menu (like viewing the graph for the selected variable) would also reverse the action. For example, it opens and closes the graph, unless another variable is selected. Right now, I have defined a custom shortcut (⌘ + E) to run ‘Output -> Close all output windows’ but the shortcut closes everything.
4. I understand that the equation editor is going to be updated but in the current version, from time to time I see line breaks when the equation gets long, but it only happens when I reopen the model. In the same session, the format of the equation will remain the same (for example, there will be no line breaks)
5. The equation editor on macOS does not accept ‘esc’ or ‘command+return’ keys. So the equation editor can only be closed using the cursor
6. I feel that the Data Import Settings window has not been updated yet because the fonts and sizes are weird. But other windows like Export Settings or Optimization Settings are okay.
- Screenshot 2024-05-02 at 10.23.27 AM.png (219.43 KiB) Viewed 633 times
7. On macOS, when the OS’s dark mode is enabled and the Vensim’s Dark mode sketch is activated, renaming a variable is not very clear as the text/color overlaps
- Screenshot 2024-05-02 at 10.28.01 AM.png (124.11 KiB) Viewed 633 times
