Does optimization with Kalman compare the simulated values with and without state resetting?
When running optimization+Kalman, does Vensim turn off the filter and run the model with the estimated parameters obtained from Kalman to see if there is still a good fit even without state resetting?
Re: Does optimization with Kalman compare the simulated values with and without state resetting?
No.
