[ADMIN]This was received via e-mail.[ADMIN]
I have problem using any of the following tools to set up my model and simulate
it:
Check Button, Radio Button, Combo Box, and Slider.
The problem is that when I use the above tools to set a constant and/or a game
variable at specific value different from what is initially loaded in a CIN
file, as soon as I click on the run button and start the simulation, the tools
return to their initial value and I do not get the simulation based on the
value of parameters that I set by the above tools. What I am not doing right?
I used different set of commands in the "run" button. Here is one example of
the commands that I put in the "run" button:
SIMULATE>READCIN|temp
SIMULATE>RUNNAME|temp
Run
SIMULATE>WRITECIN|temp
Please let me know how can I get to the mailing list of peaople who are using
sable and might have faced the same problems that I am facing now and might be
able to help me as I continue to work with sable.
[Edited on 7-8-2003 by Administrator]
Problem with updating of Check Button, Radio Button, Combo B
Moderator: Administrator
[ADMIN]Response via e-mail.[ADMIN]
This is how Sable/Vensim works. When you are in Vensim and do a run, all constants etc return to their previous values. This is exactly how Sable works as well.
To get around the problem, simply write a CIN file before the run is done, and read it immediately afterwards
Run
This will load all the values you had for the simulation.
There is no mailing list for Sable, but there is a forum, http://www.ventanasystems.co.uk, feel free to ask these types of questions there.
Run
