I just got the email re version 6 and installed the new version (DSS version). I tested it with a model I was working on that took data from excel. I kept getting an error message "Unable to read the file.....[directory string].../Data Input Sheet.xlsx as an Excel file (sst).."
I have no idea what the (sst).. refers to. I reinstalled version 5.11a and all works fine.
David
Model error message in version 6.0 (DSS)
Re: Model error message in version 6.0 (DSS)
Are you able to email the offending spreadsheet so I can test?
There have been a lot of excel changes in the new version, we must have broken something.
I've attached the excel spreadsheet referred to.
David
David
- Data Input Sheet.xlsx
- (30.45 KiB) Downloaded 250 times
Hello David,
Thanks for this. I've found where it is failing, but not sure yet how to actually fix it.
If you can change instances of " in your sheet to something like "As above", it should import fine (Baseline and Adjustors tabs).
The quote is causing problems. We are expecting a second quote to close the string which is obviously not appearing. I'll have a fix ready soon though.
Great - thanks for that.
David
David
This is fixed in 6.0b.
