Problem with Vensim Loading
yobiman
Post by yobiman »
I have been using Vensim for many years. Recently my vensim installation seems to have become corrupted. When I load a new model I get a message "Unable to open 34:0,,,.mdl to read model". Vensim opens and can run simulations etc, but the graphing functionality doesn't work.
I tried reinstalling Vensim but it didn't seem to fix the problem.
Any ideas?
Many thanks
Phil
Re: Problem with Vensim Loading
It sounds like the model got corrupted during saving. Can you click View->As sketch and see if it returns?
You might try reinstalling, but being sure to to check the "Reset Initialization Settings" box - it could be that your vensim.ini or toolset files were corrupted somehow.
yobiman
Post by yobiman »
Many thanks.. Unfortunately it didn't seem to work.
I have two versions of vensim.ini on my machine. I wonder if this has something to do with it?
Phil
c:\windows\vensim.ini
[vensim]
Units1=$,Dollar,Dollars,$s
Units2=Hour,Hours
Units3=Month,Months
Units4=Person,People,Persons
Units5=Unit,Units
Units6=Week,Weeks
Units7=Year,Years
Units8=Day,Days
C:\Users\TolagaMain\AppData\Roaming\Vensim\vensim.ini
[vensim]
Units2=Hour,Hours
Units3=Month,Months
Units5=Unit,Units
Units6=Week,Weeks
Units7=Year,Years
Units8=Day,Days
ModelsOld0=
ModelsOld1=
ModelsOld2=
ModelsOld3=
ModelsOld4=
ModelsOld5=
ModelsOld6=
ModelsOld7=
ModelsOld8=
ModelsOld9=
ModelsOld=
print_options=1,1,0,0,
size_options=0,0,0,0,
XlsOptions=82,67,0,0,
print_dimensions=10,10,,,
print_text_hndl=,,,
printer_name=,,,
ErrDim=0,0,0,0,
SelDim=0,0,0,0,
EqedDim1=0,0,0,0,
EqedDim2=0,,,,
VarDim=0,0,0,0,
DefaultFonts=Courier|10||0-0-0,Times New Roman|12||0-0-0,Small Fonts|7||0-0-0,MS Sans Serif|9||0-0-0,
GraphFonts=Times New Roman|48||0-0-0,Times New Roman|16||0-0-0,Times New Roman|12||0-0-0,,
GraphLegendFonts=Times New Roman|12||0-0-0,Times New Roman|10||0-0-0,Times New Roman|8||0-0-0,,
PrintFonts=Times New Roman|8||0-0-0,Times New Roman|18||0-0-0,Times New Roman|12||0-0-0,Times New Roman|10||0-0-0,
DefaultFont2=MS Sans Serif|9||0-0-0,Courier|10||0-0-0,MS Sans Serif|9||0-0-0,,
DefaultVariableFace=Times New Roman,,,
GraphicsOptions=0,0,0,2,
ScreenOpt2=0,0,0,1,
OtherOpt=0,,,,
name_format=0,0,1,0,
size_centimeter=0,1,,,
MacroWarningNewOver=0,0,1,1,
history_comment=1,0,0,0,
raw_scaling_flag=0,1,0,0,
FSSettings=1,0,1,,
FSSettings2=2,,,,
compile_options=0,0,0,,
TimeSlop=0,0,0,,
MAX_X_GAP=0,,,,
GraphClr=16777215,0,8421504,,
GraphClr2=12632256,16777215,12632256,,
PltClr1=16711680,255,32768,8421504,
PltClr2=0,128,16776960,8388736,
PltClr3=8388608,65280,16711935,32896,
SketchClr=16711680,-1,0,-1,
DefaultFixedFace=Courier,,,
AnalysisToolSet=,,,
SketchToolSet=,,,
Mode_Options=1,0,10,,
AdvancedOpt=0,0,0,,
NewModel=,,,
Screen_Options=0,,0,0,
PolarityOffset=14,0,0,,
SketchDefAppear=1,1,0,0,
SketchOpt3=1,1,,,
ArrowheadSize=14,8,5,,
Init_rate_size=12,16,2,100,
GraphDiv=4,4,,,
Init_shape_size=40,80,40,,
TypeShape=,8,8,,
TypeShape2=3,8,,,
GraphMark1=49,50,51,52,
GraphMark2=53,54,55,56,
GraphMark3=57,58,66,67,
Generally, that shouldn't matter.
You could try renaming them (e.g., vensim.inix) temporarily - Vensim will start with default settings if the .ini is missing. But the effect of that should be the same as a reinstall that resets the .ini, so that's probably not the problem.
Tony's test - whether you can open other models - might be more informative here.
yobiman
Post by yobiman »
Many thanks Tom,
I have renamed the ini files but still seem to have the same problem, which makes me suspect that something else has been corrupted.
When I try to create a new model (or open vensim for the first time) the error message appears
I am able to load existing models or for that matter ignore the message and build a new model. I manually reloaded the toolbar etc.. The only thing that seems to be messed up is the graph tool - which has a black background. Not a big deal
Thanks again
Phil
What version of Vensim are you using? And what operating system?
yobiman
Post by yobiman »
I am using 5.10e in Windows 7
Phil
Can you send me some images of the graph problem (vensim@vensim.com)?
I cannot recreate any of the errors you are mentioning.
And did anything change on your computer before the problems with Vensim? Anything at all (new graphics driver, anti-virus, etc).
yobiman
Post by yobiman »
Nothing that I can think of.. Perhaps it is something more fundamental to the machine. I will rebuild it and see if the problem goes away
Many thanks for your help
Phil
