Problems of publishing Sable with scripts
Moderator: Administrator
cphan
Post by cphan »
I try to publish a Sable project including a JS script file, i have the error "Error adding script file. Please check syntax" when running the spk file. My JS file has only one simple function :
function test()
return 'helloworld';
How can i fix this ?
I herewith attach my test project.
CT
test.zip
(373.34 KiB) Downloaded 1315 times
Re: Problems of publishing Sable with scripts
It looks like it's a bug when handling unicode files. I'm looking into it.
I've uploaded a new version of Sable that should fix this.
cphan
Post by cphan »
I have tried your new version of Sable but it doesn't work.
cphan
Post by cphan »
I've changed the encoding of my .js file to UTF-8, it works. Thanks!
