Good morning.
I moved my analysis toolset to the top, and now want to move it back to the left. The selection button under options is grayed out, and I cannot move the toolbar.
DSS Version 6.3, X32
Thanks.
Eliot Rich
Analysis toolbar won't move to left
- Screenshot.
- Capture.JPG (41.4 KiB) Viewed 3835 times
Re: Analysis toolbar won't move to left
I'll raise this as a bug. The "Left" button is being hidden for some reason.
But if you exit the dialog, and then click Tools->Options again, you should be able to click "Left". Don't tick the "Use old Vensim icons" as this is what toggles the appearance of the "Left" radio button.
It turns out that you can still click "Left" (just click a little to the right of the word).
The "Top" setting has some clear space after the word "Top", this is drawing over the radio button. But click the word "Left" and it should still work.
Thanks - the suggestion works. I do suggest it stay on the bug list, though the work around is reasonable.
Best,
Eliot
Best,
Eliot
