Using two differente time range
yanet288
Vensim version: PLE+
Post by yanet288 »
I have been looking for the answer of my question but unfortunately I hadn't found it.
It is about how to use a different time scale in the graphic produced from a stock-variable (with an INTEG) which is running with time scale of days. I will like to get a graph where instead of x-axis in days, I could have x-axis in Years. I am using PLE Plus, so please do let me know how could I get this "personalised graph" I have already tried with the graph customised but I could solved it yet
Thanks in advance
Re: Using two differente time range
Search the help for the TIME BASE function. I'm not sure you can use it in PLE+ though, but try anyway.
You can also define some custom graphs to give you the x axis you need.
