dll and vensim
Moderator: Administrator
ManuelM
dll and vensim
Post by ManuelM »
i'm trying to use dlls of Vensim 3 under WinXP. I first tried it with visualWork7nc with no succes since Vensim commands just don't work. I then tried the vendll.xls example supplied with the vensim3.0 software. Alltough I correctly renamed vendll32.dll file, I put the vensim.ini at the right place and I modified the paths in vendll.xls, it also didn't work and when calling vensim commands I still get 0 as result. Could you give me any advice? I was told that I should maybe modify the MDL.BAT file but in which way? Idon't know!
Thanks in advance, Manuel
Can you e-mail me what you have? I should be able to spot very quickly if there is anything wrong.
ManuelM
Post by ManuelM »
thank you for your answer.
Here is the .xls file I use. Please let me know if you want me to send you additional information.
Thanks.
Just an initial observation, you say you modified the paths in the spreadsheet, but in the version you uploaded, only the first command a path different from the rest.
I think it would probably be best to e-mail me directly and send me the model, spreadsheet and the DLL you are using.
ManuelM
dll and Vensim
Post by ManuelM »
Hello Tony,
here are the files I use. Good luck,
Manuel
ps : I corrected the paths of the Manu.xls file that effectively were wrong (shame on me!)
