use entities in new diagram
moudi
Post by moudi »
Sorry for asking again...
How do I use existing entities in a new diagram? I went to the entity inspector of the "widget" entity, created a new diagram, and wanted to use some existing entities in this diagram. It works, but I cannot link them, e.g. flows out/in from a stock. How can I do this. I assume it is a very simple issue but I cannot manage it. See the model included.
Thanks.
test group widget1 with new diagram.zip
(7.27 KiB) Downloaded 994 times
Re: use entities in new diagram
Not quite sure what you're trying to do. Do you want to reuse the same structure in a different context (Paste as New, like Vensim's Replicate), or use a reference to existing structure (ordinary Paste)? Or reuse an entire entitytype?
moudi
Post by moudi »
I wanted to paste a part of the model onto a new diagram (replicate). The structure is not fully visible (see the attached document and the ventity model). In particular the flows are not visible. Moreover, I'm not sure if the "copy paste" functionalities work properly.
copy paste problem.docx
(45.2 KiB) Downloaded 1027 times
(7.25 KiB) Downloaded 932 times
moudi
Post by moudi »
Sorry I wanted to paste part of an existing structure ("paste" NOT "paste as new").
There are definitely some copy-paste issues, which I hope will be resolved in the next release.
