Vensim problem with Pink Noise
i'm working on my research and i don't know how to fix that problem. The value of pink noise are increasing over the time, And the logic behind the pink noise behavior is that there is some oscillation over the time. I think i'm letting something behind, some variable, some incorrect value, i don't know. please if you guys could help me, i will be grateful.
- DIAGRAMA DE ESTOQUE E FLUXO4.mdl
- My Vensim file
- (15.2 KiB) Downloaded 553 times
Re: Vensim problem with Pink Noise
Have you copied the structure from the model at
http://metasd.com/2010/03/pink-noise/
