Date Display
Moderator: Administrator
klaus
Date Display
Post by klaus »
in Vensim i have defined time bounds from 0 to 36 month. Then i selected the corresponding Date displays (2018-01-01, 2018-02-01, 2018-03-01,...)
It works fine in Vensim. But in Sable (Graphs and Tables) the original time lables (0 to 36) are shown.
Thanks for your support
Klaus
Re: Date Display
Sable cannot pick up the time bounds from the Vensim model. But I should be able to limit them in a future version of Sable.
klaus
Re: Date Display
Post by klaus »
Thanks for your quick reply.
So there is no way in Sable displaying Date labels instead of Time labels in graphics and tables like in Vensim?
Best regards
Klaus
Re: Date Display
Can you give me an example of what you want to display?
klaus
Re: Date Display
Post by klaus »
here is an example.
Sable Display.png (114.95 KiB) Viewed 43886 times
Best regards
Klaus
Re: Date Display
Are you using a Sable table or an embedded Vensim one?
klaus
Re: Date Display
Post by klaus »
A Sable table and a Sable Chart.
Best regards
Klaus
klaus
Re: Date Display
Post by klaus »
Sorry, but i want to ask if there is a solution to my problem?
Many thanks for your support.
Best regards
Klaus
Re: Date Display
Sorry for the delay.
You will need some extra parameters in your model (year, month of year, day of year). Once you have these, you can insert a row in a Sable table, go to the "Format" tab and select "Use Custom Series". In here, type something like
@year@-@month of year@-@day of year@
This should give you the output you need.
You might also need to play with the number formats
@year,%.0f@-@month of year,%.0f@-@day of year,%.0f@
klaus
Re: Date Display
Post by klaus »
It works!
Many many thanks.
Best regards
Klaus
