Access to Macro outarg
Berchi
Post by Berchi »
I am using the Delay Conveyor function and I would like to calculate the number of items in the delay and the leaking flow at the same time.
I transformed the instruction that are in the VENSIM HELP into a MACRO. It works , I can see the Outarg info but I am not able to use them as variable.
How can I do that ?
Can you post a simple model containing what you want you have and an idea of what you want to do?
Hopefully it is quite simple.
Berchi
Post by Berchi »
In brief : I want to have access to the outarg variables of a MAcro.
The attached model uses two output arguments from a macro.
It can be a little confusing as the macro output arguments do not appear as model variables (but they do exist).
Let us know if this works for you.
macro.mdl
(1.54 KiB) Downloaded 941 times
Berchi
Post by Berchi »
The solution is ok.
