Apply measures to Lookup
ivancf1995
Post by ivancf1995 »
Good morning,
I have some model predictions imported to Vensim as data as a Lookup structured like: [(1960,893.015)-(2070,32121.347)],(1961,32113.695),(1962,32105.358),(1963,32096.276)...The model is complex, so I cannot do it directly in VENSIM.
My question is: how can I apply certain conditions to this data within Vensim? For example, let’s say that based on a binary switch, if the year is greater than 2040, I want the predicted population value to remain constant from 2040 to 2070, instead of growing.
Thank you in advance
Iván
Re: Apply measures to Lookup
This is just a guess as you haven't provided much to go on.
CONSTANT POPULATION GROWTH RATE = 30?
CONSTANT POPULATION GROWTH RATE START TIME = 2040 {year}
CONSTANT POPULATION GROWTH RATE END TIME = 2070 {year}
IF THEN ELSE ( time > CONSTANT POPULATION GROWTH RATE START TIME
:and: time < CONSTANT POPULATION GROWTH RATE END TIME
, CONSTANT VALUE
, lookup table (time) )
ivancf1995
Hi Admin,
thank you for your quick response. It was finally solved using your suggestion and changing de Data Table from "Lookup" to "Auxiliary with Lookup". Now I have another doubt. ¿Can I extract a value from the Data Table of a certain Year and save it as a constant? For example, Data Table contains values from 2000 to 2070, and I want to store the 2025 value to use it in other parts of the model. Such as:
"IF THEN ELSE(Time<ShortTerm,Lookup table,2025_value)"
You can use something like
value at 2025 = initial ( Lookup table(2025) )
