I have conducted sensitivity analysis and I obtained some plots that I want to compare. However, I realized the y axis scale is different and I cannot change it. For this reason, I thought it would be easier if I download the results obtained in the sensitivity analysis and make the plots myself in excel but I was unsuccessful. How can I export the data into xlsx format?
Thank you in advance.
Export results from sensitivity analysis in xlsx format
Re: Export results from sensitivity analysis in xlsx format
I don't recall if xlsx is supported, but CSV and tab-delimited are. Model>Export Dataset...
CSV opens into Excel by default.
