Sensitivity Analysis
pz
Post by pz »
Is there some simple way to obtain a detailed report on sensisivity analisys?
The graph is good, but gives just a qualitative idea of the simulation.
Thanks.
Lee Jones
Post by Lee Jones »
First of all, you can configure the statistics tool to give statistical output across all simulations undertaken. Right click on the stats tool, select sensitivity in the middle-right of the dialog and enter percentiles if required. If the stats tool is not shown, you need to configure your tool bar to add the tool. Go to Tools>Analysis>Modify from the menu and drag across a stats tool from the tool classes list on the left.
Secondly, go to Model>export dataset on the menu and select the sensitivity run. Exports to a DAT file which can be read into Excel. Have a play with the configuration options to see what''s best for you.
Hope this helps
Lee
[Edited on 14-1-2005 by Lee Jones]
pz
Post by pz »
Thank you Lee!
