Auxiliary * Lookup
lidygal
Auxiliary * Lookup
Post by lidygal »
How can I multiply an Auxxiliary with a lookup?
I did iin this way:
Lookup(auxiliary)
But in the result only multiply the first value of the lookup by the auxiliary.
Tesis.mdl
(10.07 KiB) Downloaded 428 times
lookup
Hi Lidygal
First you should correct the units error.
I never run a model that has any unit error in it, unless warnings.
Secondly the model when run gives the following error:
WARNING: At 2003 Above -Impuestos- computing -Impuestos por pagar-.
Meaning that the lookup gets value as input higher than what was expected.
The lookup expects value from 1 to 5 and gets input that are higher then 42 the
Utilidad de operaciôn.
The problem comes probably from this incoherence.
J.J. Laublé
Just to clarify - a Lookup is a function specified by pairs of numbers that convert an input to an output. Thus the normal format is
lookup output = lookup function(lookup input)
If you also want to multiply the output you can use
result = lookup function(lookup input) * auxiliary multiplier
