i want to calculate the demand's STD,
can some one tell me how to do it?
does it have any function in vensim can use to calculate one variable's STD
thank you ....
how to calculate the standard error in vensim
standard error
Joined a model where you have every time steps, a set of variables generated randomly but can be loaded from real data, and that calculates each time step, the mean and the standard deviation of the set of variables. Vensim pro needed.
Jean-Jacques Laublé
Jean-Jacques Laublé
- stdv.mdl
- (2.68 KiB) Downloaded 487 times
standard deviation
You need to be more explicit about your needs.
The standard deviation is not necessarily the solution to your problem.
If you want the std from a variable, you have to define a trend for that variable, wich is for every time step, an expected value for that variable base on its historical data, and then calculate the standard deviation of the real value from that expected value.
The simpler solution and generally the more efficient to predict the demand is to take a running average eventually
weighted with the oldness of the data.
Did you study the afore mentioned chapters from business dynamic's?
