How could I control a decimal point.....
gk720421
Post by gk720421 »
How sould I do when the final number's decimal point
Such as 5 ,5.5 , 5.58 or 5.586
Go to Tools->Options then select "Settings". There is a checkbox near the bottom for "Use European number format for displayed output".
Hope this helps.
gk720421
Post by gk720421 »
thanks!
gk720421
Post by gk720421 »
How could I select in vensim to do "523"------>"523.00" or "452.293"---->"452.29"
thanks
gk720421
Post by gk720421 »
I find that
It show that if answer should be "5.281"---turn -->"5,281" I assume answer is 5281 ,not 5.28
how can I improve?
thanks.
If you are using European number formatting, 5.2 will show as 5,2. The number is still the same (5.2 = 5,2).
Originally posted by gk720421
I find that
how can I improve?
thanks.
Are you using the table tool? If yes, right click on the table tool and you can see some options. Experiment a little with "number format" and see if it does what you need.
All the best,
gk720421
Post by gk720421 »
thank you very much!
