Problem with combo box
Moderator: Administrator
mashayekhi
Post by mashayekhi »
In a combo box, I am using an auxiliary variable that is qualified as a gaming variable. This auxiliary variable is set equal to a constant. I have given different values to theis auxiliary variable in the combo box. But when I simulate the game the combo box does not function, i.e. it does not change the value of the game variable to anything other than the initial value given to it in the model. What can be the problem?
Can you post a demo project of what you are doing? I cannot recreate the error here.
mashayekhi
Where can I find an example of combo box used in a project?
The examples that you supply with the software there is no a combo box. It will be helpful to include an example with combo box and if possible with all the tools available in Sable.
